Headunit for toyota camry altise
freshaltise08
Thanks sportivo2007, you re my hero. I put the "PZQ60-00161 antenna patch with the speakers" in and I got sound. I got the rest tomorrow and hope it will work with reverse camera.
I bought this for $500 and I think it better than Chinese stuff :)
I plugged these 2 harness, but my reverse camera didnt work. I think I need another harness. Would you guys give me any suggestion pls? Thanks alot
Hi sprotivo2007,
Here is the connection out of my car for reverse camera and steering wheel control
And the harness I have, I chose this harness because it said it concluded camera connection, but I am wrong
Waiting for your advice bro, thanks alot
Edited by nhp
Hi sportivo2007, the camera is genuine one. I think it needs a harness, but I dont know which one is suitable. Waiting for you bro. Thanks alot
Hi bro the camera connector comes together with wheel control in the first 2 pictures I uploaded. That is why the harness I got is not suitable
Edited by nhp
OK so the camera came your car right ? and you just added the unit ? or you added the camera ?,OK by the looks of your plug i think you will need to get the PZQ60-00151 camera harness, but don't take my word on that , give it a try its $22 bucks ,i think its the right plug
don't forget the harness has speed sensor which goes to the purple wire in your steering wheel control plug, and you also have the reverse signal wire ,which is on the Gray plug on pin 5 ,but you might get away with just plugging the extra harness in if your car came with a camera ,it might be all done , here is the harness close up
The female connector of the 151 harness is 28 pin while the connector comes out of my car is 20 pin bro. I think it needs some modification. I asked a toyota dealer but havent got respond. Hope they will help :)
I tried to connect the red wire with the blue wire in 141 harness but it didnt work too. I think it needs a power source for the camera but I havent tried
So you havent got new HU, I think there is some choices for you
A. Go to dealer, no headache but cost around $1500-$2000
B. Go to wrecker, got a used piece, do a DIY or Bring to dealer
C. Go a aftermarket.
Ok, go ebay, search one, try to get a camry compactible, just plug and play. If you want to do a DIY, go to google and search "camry 2007 head unit replace" or some thing like that, that is the way I did. If something confused, come here and I ll try whatever I know.
But remember what you pay is what you get, so dont try too cheap
Uhm not really, I used 141 harness, add a 4 pin connector and connected reverse signal to pin5 of connector comes out of my car, if you want I can take pics
Edited by nhp
