Exhaust type question
One thing I forgot to mention before about the Remus muffler, not sure about the units that are designed for the Sportivo's, however the unit designed for 100kw IZZ-FE 1.8's such as mine is not engineered to give you much of an increase in high end power (only 5kw increase), however it is specifically engineered to give you increased mid range torque. This means that it gives you increased urge between 2500 and 5000 rpm. You feel the difference most when pulling out of corners. But also the downshifts are much smoother because of the reduced back preasure (And sound Great!).
