The Multi-information display screen
DDC73
G'day all
Just curious with this information screen , i was wondering (besides doors open , trip computer and climate display) , what other features or warnings does it display?. The hand book does not go into detail , but just says when the warning light appears on the dash , to then check your MID screen to see what the issue is.
Thanks Dan :)
Hey dan, apart from all the usual stuff you mentioned it also show all warnings, such as low coolant level, low oil level and the like it even shows low windscreen washer level! It really is a very helpful piece of equipment. (Oh yeah it's your reverse camera as well)
Skip
  • 6 months later...
Hi Skip,
thank you very much for the post. Are you aware of any problem for this MID? My one makes a continuous beep noise all the time, even the ignition is off. Any ideas? cheers
Usually means the keys are in the ignitation and the drivers door is open.
Thanks Dan for your reply.
The continuous beeping sound is from the MID which I have disassembled and located the source of the sound-bottom circuit board of the MID. It beeps all the time even the key is NOT in the ignition.
      New member seeking advice for parts
    2. 39
      Pics of my Kluger steering wheel removal
    3. 14
      1zz to 2zz
      Can I put a 2010 bumper on my 2008 Camry ?
      Anyone else tried these seat covers ?
      Digital Speedometer
      am2 fuse blowing
      Toyota Celica '96 5S-FE no spark
      Toyota Camry 2003 Driver seat recline issue
