1986 ST162 Celica 3S-FE parts
Bushfunk
I'm the proud owner of a Celica that is in tremendous condition in the way of interior and body but I have recently moved interstate and need a safety certificate in Queensland (Cairns). I took it in and it failed due to oil leaks so it looks like I have a bit of work ahead of me. The leak list is as follow:
*tappet cover leak
*power steering pump leak
*passanger side axle seal leak
*rear main leak
*sump leak
also engine mounts cracked and needs new front break pads.
As not doing the work is not an option all the help I could get would be greatly appreciated. Things like what parts I will need where to get the parts and any helpful hints along the way. I do have access to facilities and tools which is on blessing.
