how can I remove my rear bumper completely?
Silver-Aurion
So I just won this on ebay: http://www.ebay.com.au/itm/Toyota-Aurion-Sportivo-rear-bar-/130997938831?_trksid=p2047675.l2557&ssPageName=STRK%3AMEWNX%3AIT&nma=true&si=dDNvtEk3LIrtcTZPFA9lr7Mq02M%253D&orig_cvip=true&rt=nc
And hopefully it looks good in person as it does in pictures and doesn't require any body work and any scratches can be buffed out etc.
Will hopefully be picking it up tomorrow morning as the guy said he is too busy today to come down.
Does anyone here have pics/walk through on how to remove the rear bumper. Searching just yields how to remove front bumper.
Easy as man
In the middle directly under boot there are 4 screws.
2 screws in recesses .under wheel arches ( 1 either side)
1 screw each bottom corner them carefully peel back
There are clips that run the length too
2010 zr6 don't know if different on yours
I if you have sensor be carful because the wires are short as
Easy as man
Thanks for that. I hope it ain't too difficult to remove and put the new one on!
No probs man I was home I'd posts pics. Mine is stock Sportivo kit so should match bolt holes perfectly.
Make sure when playing with one side, cover the other loose side with a towel or something so you don't scratch your paint on side panels.
