1KD-FTV White/Grey Smoke
Alexi Christidis
Hi Guys
Have been having this issue and wanted to run it by this forum to see if anyone else has had it.
have the hilux with the 3.0 Litre turbo D4D engine, 1kd-ftv.
White/Grey smoke on start regardless of car temp...worse in morning but if sitting there for half an hour will also smoke.
Mechanic pulled off intercooler, oil all through the turbo etc, turbo needed bearings, seals done. So did that. Still smoke...argh.
Had a closer look, number one injector buggared. Replaced all injectors. Got car back yesterday yet still smoking!
When i start it i notice that the times it smokes it has a little shudder after ignition like it's trying to 'catch up'. If it doesn't do that it doesn't smoke.
Any ideas?
Cheers,
Alexi
Guys, its the injector o rings split and leaking into the combustion chamber, FACT, if the front one is split, noise down it will smoke badly on start up and i have had my own KUN hydraulic on start up, please do not let anyone tell you its the injectors or the turbo or the rings, they are uneducated on the subject, do not want to be a 'know it all. but i have been a mechanic for 35 years and had this problem with my own vehicle, happy to advise anyone needing assistance,, love to help.....
    2. 14
      Hi from Wagga
    5. 2
    6. 2
    7. 2
      Engine oil dipstick reading
    9. 1
      Landcruiser 13B Engine Swap
