Windscreen rattle
Jonnykluger
I have a 2009 kx-s kluger and recently I have noticed a faint glassy kind of rattle coming from the driver side at the top corner I have tried to see where it was coming from without success.I'm assuming it is the widscreen however I could be wrong ,it may be either on the inside or outside ,and happens every time i go over a rough surface.It has become very annoying and I was wondering if anyone else has had this problem with their Kluger and have found a solution is this common ?
Edited by Jonnykluger
  • 4 weeks later...
Had the same problem in mine top right of windscreen was rattling all the time , had to replace windscreen in the end was going to get it removed and re sealed but had a stone chip so I had a new screen fitted. Solved the problem, it wasn't sealed correctly from the factory. No more rattles.
Just have an update on the rattle have traced the problem to the plastic cowl on the outside of the windscreen under the wipers .i have heard there is a problem with this on other toyotas was wondering how I could get this fixed since the car is out of warranty and I don't particularly want to try and remove the cowl because I may not be able to get it back on .
