Aussie's 2005 Stivo
Aussieakito
I was never really happy with the way the yellow tint on the fog lights turned out, so the other day i ripped off the tint.
Everytime i looked at the front it just seemed to be missing something without the yellow.
So today... in the rain i decided to take them off to re do the tint properly.
Cleaned them up
11990491_10206062620016805_4910921188370
This time im using a heat gun to stretch the tint out and put it over the glass.
11057765_10206062620096807_4693811510498
This worked perfectly, i managed to get a completely wrinkle free/bubble free tint!
12036620_10206062620416815_8244891657467
Excuse the in house pictures (The garage is currently getting a massive clean out)
Also excuse the iPhone pictures
So, i removed the factory air box and intake to fit a "cold air intake" with a pod filter.
i kept it on for 1 day before removing it and refitting the factory airbox.
Now i ask... whhhhhyyyyyyyyy do people like pod filters?
it sounds TERRIBLE!
Have a terrible iphone picture of the car back to normal.
12003377_10206096558145237_2571495015880
So as you may of seen i had my drive shafts reconditioned.
They are now clicking so i took the offending drive shaft out today so that tomorrow i can drop them off to be fixed once again.
Luckily they are covered by warranty
The fluid was still perfectly clean which was nice to see
12107964_10206165357065167_3320973120364
12107964_10206165357345174_5808342425379
This means i need to drive my SS to work which scares me as i dont want to get in any trouble so close to getting off my P's.
Forgot to post an update once i was done.
Had the drive shaft all sorted the next day, they tried to tell me that i cracked the housing on the outer cv.
After a little bit of an arguement they agreed to fix it for me under warrenty.
Today how ever i bring you another update, i could smell coolant this morning so i had a look around the engine bay and spotted a drippy waterpump
Removed it today, will fit the new one i have on order tomorrow after work.
(was leaking from the welsh)
11230107_10206267625141805_6363416661387
12122761_10206267624421787_7012360854213
12191519_10206267624661793_7869110025959
The heater hose that i had to remove to be able to bleed the cooling system decided to leak (****ty spring clamps)
So had to replace it with a worm drive clamp...... and bleed it all over again.
Anywho gave her a polish today
12194659_10206286234407025_3475198544798
Installed a relay into the Headlight switch circuit so that the headlights turn off when you turn the key off, was used to the calais/SS doing that so wanted this to do the same.
also installed a kill switch while i was at it, cant tell you where though.. or what its disabling :P
Alright so got my service items for the weekend, also needs a set of wiper blades and going to machine the front rotors as they are looking a little worse for wear.
****ty Iphone pic
12240368_10206371115448998_8753896428187
Edited by Aussieakito
Nice Sportivo man!
I recently had a leaky water pump after buying my car (buyer advised me beforehand about the pump needing replacement).
cheers man :)
this weekend i need to do a sump reseal and oil level sensor seal on this to make it completely leak free
I was going to machine my front rotors at work today since they were looking a little scored and glazed but when i measured them they were undersized.
So i got straight onto the phone to BrakesWest who always look after me with some new front rotors and pads.
Turns out sportivos have 30mm larger rotors than a standard corolla, and slightly thicker too.
List of things this car is getting this weekend
-Mobile 1 oil
-New oil filter
-New iridium spark plugs
-New front rotors
-new front pads
-new oil level sensor seal
-Sump re seal (due to having to take it off to unbash it)
- Fresh coat of paint on the calipers
- Rotate wheels
-New pollen filter
-New Air filter
-Brake Fluid Flush
-New wiper blades
In the last few weeks its already had
-New clutch, along with machined flywheel and clutch fluid flush
-new driveshafts
-new waterpump
-coolant flush
-new gearbox oil
So fair to say i take care of my cars ;)
I find it hard to ignore a problem.... call it OCD
Random iphone snap of brakes.
12185424_10206391363195179_5560822904941
