Corolla ZRE 3rd brake light on spoiler
Has anyone seen red glass on the 3rd brake light which is on the ZRE152's spoiler? All I've seen so far were with white glass. Why might this have the red glass and can it be replaced with white one (eg. is it possible to order the glass separately and is it easy to remove)?
Edited by Speed_Chaser
I,m pretty sure yours is the first run of the series,2007, hence having full red tail lights where as the wife has the upgraded/ face lift late 2011 model sports and it has clear 3rd stop light in spoiler and the top section of tail lights are clear as well as having indicators in retractable wing mirrors not in the guard, another tell tail is the long aerial, later versions of the same series have a small stumpy aerial,
Edited by CONROD
Ok thanks for reply, but I think it might be not like that. Because I've seen pics of cars which are 1st gen and still have the white glass. One explanation might be that the whole spoiler is optional and they have bought later than the car, or is it stock part?
Also, would you be able to check if the glass can be removed and replaced?
Hey Alex they're all white/clear, that one pictured might have been tinted red or the only other replacement that I know of is from Valenti, also I think Garax make them.. The same light is used on other Toyota's but not sure which models exactly, some vans, hatches etc ....
http://valentijapan.com/products/lhmsl_toyota1.html
