AE101R VIN not recognized
I have a 1994 corolla seca AE101R HPRKA frame number: 54AEA1OD302807  VIN 6T154AEA1OD302807
There is no information at all when checking the above numbers. Does anyone have any clue ?
Where are you "checking" the VIN?  If you're trying to find things in online parts catalogues they won't show up as they don't tend to cover the Australian-built cars (ie those that start with 6T).
Also, in that VIN you quoted you put an 'O' in there, VIN numbers cannot have the letters 'O' or 'I' as they are too hard to distinguish from the numbers '0' and '1', so that'll cause problems with any VIN checker you use regardless.
20 hours ago, petermoses said:
I found the VIN in VIN-INFO. The "O" not allowed in North America but ok in Australia.
No, 'I' and 'O' are not allowed in Australia either (neither is 'Q'), it is just that some systems have the smarts to normalise them to 1/0 as needed when you type them.
https://www.ppsr.gov.au/vin-vehicle-identification-number
