Another problem .... whats going on ???
hijecked indeed .. hahah
anybody else have a gas leak ?????
Hey don't blame me, I thought it was a related question <_< With little knowledge of how A/C systems work i'd guess i've got an air bubble or something but being a gas system that wouldn't be possible would it?
Anyway you can get a dye to check for any possible gas leaks, also they advise you use the system at least once a week (or was it once a month) to make sure the seals don't crack and leak.
mate .. all good .. just a laugh ...
The guy at the service said they would use a dye first to check for leaks .. if they ant find it they will just re gas and see what happens ...
here is another question ...
if there is a gas leak ... can it explode ????
      Code P004B
      Upgrade from 2012 to 2023
    6. 3
      Towbars
    7. 5
      ASV50 Camry Head Unit Options
    9. 2
