want to install 2 ways 6.5 speaker
trd
i had this done but i did not do it myself. it was done by the company i got my sound from.
I think there are a few screws and then you have to gently pry it with a screw driver so it pops away from the door.
Or you can go to toyota and ask them how its done.
please help me to remove the door skin. i don't know how to do it and install the 2 way 6.5 speakers.
thanks
TRD
There are 3 screws in the door which u must remove. The first screw is behind a little plastic clip on the thing(no idea what it is called) that u pull to open your door. In order to remove the 2nd and 3rd screw you must remove the arm rest thing on your door. Just apply constant pressure and it will come off. After removing all 3 screws. Just pull the door skin toward you..applying constant pressure and it should come off. I'm not sure if this makes any sense..but if u got any more question just pm me..
      1987 Toyota Corolla - 60 000km on the clock
    2. 3
    3. 3
      Toyota Landcruiser problems
    5. 13
      300 series turbo issues
    6. 55
      Stout Owners
    7. 13
    8. 8
    9. 55
      Stout Owners
    10. 2
