HELP! where does the wires connect to?
i have just recently bought a air/fuel gauage, its has 3 wires, green, black and red, where should they be connected?
red and black would be the power and the green would prolly go to the O2 sensor wire in the ecu loom
Thanks Northy, but how do i know which wire in the ECU is the O2 sensor wire?
take not of the wires that come through the floor of the cabin just to the left of your knee/feet in a normal driving position ;)
the black and red are for ignition and ground (don't connect direct to battery as the light will be constantly on)
oh ic then, where should i tap the ignition wire from? is it ok if i get that from the headunit or the clock? :wacko:
