To access the phone functions you need to press the green handset button, then turn the tune knob to choose the option, and press the tune knob to select. The green handset button also answers calls. The red handset button gets out of phone mode completely and hangs up a call. To pair a phone you need to: Press the green handset button Turn the tune knob and select BLUETOOTH turn the tune know and select REGSTR PHONE It should display HANDSFREE. Scan for bluetooth devices on your phone Select HANDSFREE from the list of devices The pin code will show on the radio display and enter it into your phone. The radio display will show WAITING and then COMPLETED once connected Press the red handset button to exit the phone mode. You can change the bluetooth pin somewhere under either BLUETOOTH or SETTINGS. You can pair multiple phones although you need to manually select which one to use. This occurs under BLUETOOTH->SELECT PHONE The unit will not download and store your phone's address book, however you can assign up to 6 speed dial numbers by using the 1-6 keys on the unit. There is a setting under PHONEBOOK somewhere. When entering names and numbers you will need to hold down the Tune button once the last number/characted is entered. There are two ways to make a call: Dial the number from your phone to initiate the call. The call should transfer to the handsfree once it starts dialing. For the programmed speed dials, hit the green handset, press 1-6, hit the green handset. To end a call either disconnect with your handset or use the red handset button on the unit. Turning the volume button during a call changes the speaker volume of the call. There are some other functions, but you will need to explore the menus. The handsfree functionality is pretty basic. You can only access the calling functions for the handsfree when the vehicle is in motion. Hope this helps.
