dakota
dakota last won the day on December 17 2016
dakota had the most liked content!
    03 Corolla
dakota's Achievements
Rising Star
Rising Star (9/14)
  1. I've worked in the industry for a very long time..and I know for a fact that most manufacturers will look (quite hard too) for reasons not to do a warranty repair... A dealer can "say" anything they want..if it's not in writing it's not worth a cracker..when it comes to repair time the warranty clerk will go by the book, and if a cars been modified (even TRD stuff) beyond standard, and they dont feel inclined to do the repair, you'll be on your own buddy. I guesstimate a blow up rebuild for a 2ZZ-fe done at a Toyota dealer would be upwards of $10k....(based on the same job for a Camry 5yrs ago at $7500) Is it worth the risk..??
  2. My mates company lost so many $32 covers on their ascents, ( they are a very loose fit and often drop out if the cars used on rough roads ) they had them siliconed in..works a treat. And yes just put your hand up behind the cover and a slight flex and a gentle push is all thats needed to pop them out.
  3. Yeah ..watch the old "yr Injectors need cleaning .." (@$200.00) Cannon(Camberwell) 'll try this at as low as sub 30K B on yr guard dude....
  4. Cannon (Camberwell) have lost the plot too ...they dont listen any more, and just seem interested in trying to push their big buck service add-ons (non Toyota $200 injector clean at 29,000k), stuff it, I'm not going there any more. My one experience with Nunawading was very good, superb clean bright workshops and staff that listen with interest....I'm using them from now on Black455 how did Cannon lose it for you ??
  5. To avoid warped rotors it is very important NOT to complete a period of heavy hot braking by sitting stationary with your foot hard on the brake, stick it in neutral and use the handbrake, (for example sitting at lights after descending a steep hill.) What happens is that the heated pad creates a hot spot on that portion of the rotor, which then cools at a different rate to the rest of the rotor, thus causing it to warp.
  6. Please believe me..I'm not stirrin..but I've been in the trade, and m guessing a full gearbox rebuild (ONLY back to where you were, NOT any better) in a Dealer using Toyota original parts could be about $7500.00 plus. Can anyone check to see what the diff is between a std IZZ-FE clutch is and a 2ZZ-FE clutch is ?? You should be especially interested in diameter, spring stiffness, and friction type... Everything should be a minimum of 40% plus , if it's the same, or similar, you've may have a case for having a product not suitable for its sold intention... Good luck ....
  7. cheers everyone, thanks for all the advice...gee I love this board..everyone helping each other..cool.
  8. OK here we go ... will a standard 'Stivo back box bolt straight onto a IZZ-FE flange ?? and wtf do they have those springs on the bolts for??.. and will it make any difference (I'm guessin YES..better flow. ). OK guys shoot me down in flames....!!
  9. I seem to recall there's a reference to rattles not being covered by warranty in the front of the Corolla owners manual.. Last year I saw this dude on an american Corolla site who'd totally obsessed out over all his rattles and stripped the front of his car out finding them. He was posting pics as things progressed too. He fixed 90% of the noise and rattles in the car and most of it was due to cheap plastics parts with fasteners that would never be tight enough. I remember him saying the plastic wiper panel was causing a lot of the noise vibrating. He carefully siliconed or padded any thing that had a likelihood of rattling, he even had a before and after DB graph... I'll see if I can find the link.
  10. imek have they given you a quote ( $$) for the new front rotors ??
  11. It's a Levin, not a 'tivo..........( I wish !...u lucky fellas !!)
  12. Rollamods they invoiced as follows...... Oil Filter #TO90915yzze1 $19.84 Plug Gasket TO 9043012031 $1.56 Air Filter TO1780122020 $39.16 4x Plugs TOK16RU11 $16.12 4lts Coolant T00888980086 $41.87 Brake fluid NGABF 050 $9.88 None of the above included GST How do these prices compare with other dealer service invoices...I think they're a bit rich ??
  13. Cheers Guys, all your advice is much appreciated, and Zee and Pecker I think you've summed it up nicely . I am ****** off because up to now this dealership had done the right thing by us, and I'd recommended it on the board. I only go to a Toyota dealership because I want ONLY toyota recommended servicing as per the book, and ONLY toyota parts used. Clearly at only 30k this car DIDN'T need anything extra doing, it's actually getting much better as the kms rise not worse, we hadn't complained of rough running so this seems to have been just a rip for extra cash. Toyota themselves really need to look at this........... For those interested in prices the 2yr service (without the dodgey $198 injector clean) ended up as follows :- Labour $210.00 Parts $128.00 Magnatec $35.00 Misc $14.00 GST $39.00 Totalling $426.00
  14. OK as we speak the 'rollas in for it's 2yr service, it's only done 30000k though. It's a biggish service, fresh coolant air filter brake fluid etc, the car is used only by my wife and she was told $420' ish all up. it's 10.00 am and they've phoned her at work and told her it needs an" injector service" at an extra $198 !!!! it's not a proper "remove injectors and ultrasonically clean" service, it's something else. She told them no, but I want (urgently) to get your guys feeling on this, especially pricewise...thanks fellas..
  15. If the noise is apparent on over-run, coasting without throttle, it is usually symptomatic of a worn gearbox bearing. Drive belt tensioners were often replaced on IZZ-FE MR2's to fix a rattly engine sound, and made a big difference, dont think local 'rollas have needed new tensioners fitted yet and of course that's not a gearbox issue.
