gouKi
    RunX RSi
gouKi's Achievements
Contributor (5/14)
  1. heres an option from south africa http://www.playtoyclub.co.za/forum/viewtopic.php?t=9186
  2. just found this from here http://www.cardomain.com/ride/2949167
  3. bump! - only thread i could find about the Injen RD2076 intake. i know it will be 3 and half years since the last post. so Daz & beh & whoever else fitted a RD2076 - fitted like a charm no modification necessary for the facelift Sportivo?
  4. so you have the injen CAi installed. is it a good 'fit'? whats the make and model of that rear strut bar and where'd u buy it (off ebay maybe)?
  5. a solution if you wanna have the CAI and not SRI (for those watery situations). http://www.aemintakes.com/air_bypass_valve.htm I personally think, if u race your car, the CAI will be better. The 2zz-ge needs to rev high to make the power and that's also the rev range within which u race.
  6. do you mean ITB's? off the GTi-R? is that lowport or highport?
  7. check out this thread http://au.toyotaownersclub.com/forums/inde...showtopic=23851
  8. i wonder if i have the same issue. it rattles pulling away in first gear/basically that initial period til the car has momentum. then its gone. Another situation, approaching a speed bump in second gear - slow down, then accelerate - it makes that rattling again. Also with A/C on i think its a bit noisier on pull away. If u don't have it replace soonest, i guess something really nasty could happen to the engine?
  9. with all the advice running around making big power, u need to put that power down. LSD box, sway bars, drop the car (eibach/whiteline/coilovers etc) & improve driver skill.
  10. highly subjective, but here goes my suggestion Hyperblack like this Rota Torque
  11. apologies for bumping an old thread. Searched but never quite found what im looking for. What is the general consensus on a 17" rim with 205/45/17 tyre? 40 offset, with 7J? and with 215 tyre, 42 offset 7.5J? thanks
  12. nice. that 2 door is hawt wish got 'em here in SA
