Hi guys,
Thought I'd have a crack at replacing the loading screen for iGo8 with something a little more appropriate for an Aurion.
Disclaimer: not a graphic designer, can just tinker in photoshop a bit.
Here's what I came up with:
I've dropped it into mine and think it looks ok, here it is loading up 15 minutes ago (apologies for shaky hands):
If you want to add it to yours you'll need this: http://tyrande.odynia.org/aurion/loading.bmp
In your IGO8 directory find the data.zip file
Unzip this somewhere (keep a copy of the original for backups)
Copy the loading.bmp file into <where you extracted the file to>\ui_igo8\480_234\ (replace the existing loading.bmp)
Zip the folder back up to data.zip and replace it on your SD card where you found it
If you're using windows XP/Vista too you can just double click the data.zip file, go to ui_igo8 and then 480_234 and drag your new loading.bmp into this file - it should zip it in there for you.
If someone else wants to have a crack at making a nicer one please do! Happy to supply the PSD for my attempt. :)
bok
