its definatly oil man, my coolent temp enrich is high but its definatly oil.
i did a compression test last night, compression was ok
did a leak down test too only between 4-8% leak down which tells me its not glazed bores and not getting blow by.
the spark plugs where nearly dripping of oil though and there was a pool of oil sitting ontop of the pistons
its either valve stem seals or valve guides, id think?
yeah its gotta be something in the head... like i said, your seals probably went hard from lack of oil for however long, and now they are shot.
correct! dont want to do valve stem seals then find out the real problem is valve guides. but to do valve guides its a head off job
Just pull the head off and do it all at once man
so much effort cuuuuuuuuuuuunnnnnnttttttt. plus i wouldnt do it myself. thats one thing i havnt played with, thats heads. i like getting head though.....wait what
