Tutorial 1 Comment Recommended Comments Toyota Hiace Owner 0 Posted September 10, 2023 Share Hi there is no specified interval for replacement of timing chains only timing belts which in Toyotas are usually replaced every 150,000km. Timing chains are in internal to the engine and lubricated by engine oil and do not need regular replacement unless a fault occurs. Quote Link to comment Share on other sites More sharing options... Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Add a Comment × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Comment
