well ive just finished this mod the other day its relitively simple provided you solder and properly insulate the joins youll have no issues with it
**NOTE THIS IS A GUIDE ONLY IM NOT RESPONSIBLE FOR ANY ISSUES THAT MAY ARISE FROM THIS**
what youll need:
2x stop/tail globe holders i cut mine out of an old honda from the wreckers i got them for free
2x stop/tail globes bout 5-10 bucks
soldering iron
solder
drill if you really want
insulating tape or heatshrink
silicone gasget sealer
first pull out the tail light and unplug it from the wiring harness the inner lamp hole isnt cut for our models so itll have to be cut out you can use a drill to drill around the top to cut out the hole but i found just melting it out was much easier.
tutorials-1-0-71914600-1332505899_thumb.
this is the part that needs to be cut out
tutorials-1-0-95495700-1332505901_thumb.
this is the side i tried drilling i needed to clean it up with a soldering iron on the edges
tutorials-1-0-77320300-1332505900_thumb.
the plug i used 3 wires one for earth, park and stop
tutorials-1-0-02817000-1332505903_thumb.
the wires off the plug needed extending the wiring goes as follows
white/green stripe= earth
green/white stripe= brake
green= park lamp
these wires i refer to are the wires on the the tail light that you need to hook the extra light socket onto.
do not cut the wiring on the tail light just strip back the insulation and wrap the additional wires around them and solder them and either tape them up so they dont touch the other wires or use heatshrink if youve got it
tutorials-1-0-21131100-1332505905_thumb.
putting in the globes seeing as theres no nodules to clip the globe housing into the tail light so i just melted the tabs off the sides of the globe holders
then i ran a bead of silicone gasget around the part where the globe holder goes into the tail light and simply pushed the gobe into the hole and waited for it to dry then reinstalled the tail light.
tutorials-1-0-10067100-1332505904_thumb.
heres one side done
tutorials-1-0-11673900-1332505906_thumb.
and both sides done
