need thoughts of these headlights for my aurion!
In my humble experience with our car and Toyota - the majority we came across travelling around Australia towing a van is they are uncaring, irresponsible and possibly dangerous. One of them forgot to tighten the front wheel. Imagine the disaster if the wheel had decided to part company at 90kph towing a 3t caravan. -
02 mcv20r no go
have a 02 camry with 1mzfe engine...runs lpg as well as petrol. lpg mixer suffered a intake preiigition and had to be rebuilt. however will now willnot run on petrol. fiers but immediately stops. have replaced eveyrthing from fuel pump forwards, mas,ignition module, ecu, etc. no fault codes on obd2. had a local mobile mechanic have a look with no joy....any thoughts out there? -
Towing with landcruiser 300 series
Good practice to tow in 4th. Lots of information on the now defunct LCCOL forum but everyone was in agreement about towing in 4th. I have done this towing a 3.5t rated van. Fuel consumption is so similar it is not an issue. It is more about getting the engine spinning. New diesel like to spin as opposed to chug along like the old style ones. Proof for me was when I had the ECU remapped and installed a lockup kit. Whilst the car was happy to hold 5th and 6th - extra power and locked - the EGTs were telling a different story. Towing in 4ht at a GPS 90 - 95 kph turned out to be the best combination for forward progress and fuel consumption. -
Remote batteries going flat very quickly
There was a post on the now defunct LCOOL forum whereby you could put your remote in a 'sleep' state and save the battery. It seems the remote is constantly looking for a signal which in turn drains the battery. -
Major Oil Leak
tragedy has struck 😔... my 07 SX6 suffered a major oil leak this morning. Got a low oil pressure alert, pulled over. dip stick was bone dry with small amounts of metal flakes on the end. i'm assuming the leak is caused by either the oil cooler lines or the vvti rubber line deterioration. Car has been towed to my house. Whats the best course of action now? fix the leak and do a few oil flushes? or do i need a whole new motor? -
TRD Front Strut Brace to suit ZZE122/ZZE123
1 x Used original grey TRD Front Strut Brace to suit ZZE122/ZZE123 (Discontinued years ago – rare): In excellent condition for age, minor cosmetic issues near bolts. Advertised elsewhere as well. AUD$420 Cash pick up only NO OFFERS PLEASE– located in Elanora Qld 4221. I have repair kits for the centre console door available also- oem
- strut brace
(and 3 more)
Tagged with:
H7 12V 55W Replacement - No Retaining Clip
Hi all, I lost the hi beams retaining clip for the hi beams bulbs on my Toyota, is there a replacement that I could get that doesn’t need that retaining clip? will take any help. The stock bulb for my vehicle is below.- 2004 toyota corolla
- toyota allex
(and 1 more)
Tagged with:
ST-162 front door-glass seal availability
Hi all, my wife has a 1988 ST-162 Celica which I have been lovingly caring for since we met 25 years ago. It is in VGC, but of late the wind noise at freeway speeds has become much louder, and with the current wet weather the front doors are leaking rain through the 'seal' point between the window glass and the door seals. The doors are hanging in the proper position and the windows do not seem to be unduly loose in their carriers. I am trying to find a new set of door seals to try to fix the problem, but have had no success anywhere. Any ideas or suggestions would be most appreciated! My mobile is 0427 478874, or reply here! -
It was done right 5 months ago.. ok… Now I am even more scared.. cuz it was done by Toyota Service Centre.. they replaced both brake pads.. 😖😖 -
Not sure how many of the old guard are still around… fluids drained, fuel tank cleaned and lines purged, might be time to throw it into gear again.- 1
