18x7.5 Rims
$ANGELO$
If your going to slam it then yeah, go for the 215/40/18. From memory though that is even rarer than the 225/35/18's
Plus you have to meet a load rating so your tyre search could be drawn out and costly.
Like I said, i'm on 225/35/18. Full locking is rare for me and only done at slow speeds if at all. I don't like to stress the steering rack by going to the extremes so rubbing isn't too much of a problem.
I'm looking for a new set of 225/35/18 at the moment and there's nothing decent under the $220-$250 mark.
not sure corzza, I'm by no means a tyre expert...youd have to find someone with one of those little books with all the load ratings...
alternatively could just give your local tyrepower a call?
Or if you know the weight of the corolla check this bridgestone website page.. you might be able to suss it out..
Bridgestone Tyre Info
L.
L.
Thanks mate! :)
They were cheap so i had to get them!
I had others in mind but they were more pricey!
Not sure of the offset. 40?
i was told they are lows but some asay they super lows
9 mm thats nothing really but 3 % is.... so when u read 100 on your speed your cars really doing 103 ?? or is it 97 ??
does anyone no if u can get 18's with tyres and stay the same as the stock stivo rim / tyres.
thanks
Edited by magic
well it doesnt throw my speedo out by much. iv tested it on my GPS.
I drive at 100 and i think it said i was doing 102 on my GPS.
Remember the speedo could also be out from factory
i would then suggest with larger rims drive with your needle just under the limits.
so just under 60 or 80 etc.
cameras dont snap 60 or 80 on the dot.
yer true.
thanks for the replys mate
      1987 Toyota Corolla - 60 000km on the clock
    2. 30
      Where is the remote receiver on a 1998 Camry
    3. 30
    4. 3
      Getting a 99 CSX Camry into remote programming mode
    5. 30
    6. 30
    7. 30
    9. 3
    10. 3
      Toyota Landcruiser problems
