Hubrings?
TheStapler
yep, you can get them from any of the usual tyre/wheel places, or direct from the wheel manufacturer.
do you know what size you need ? is it for a corolla ?
i have some 54.1mm(corolla hub) to 67mm rims .. you can have for cost of postage
not sure what size i think they are like almost 7cm.
this there any special way to measure the centre hole?
are they hard to put in?
are hubrings safe to use?
thanks
Edited by TheStapler
thanks
Perfectly Safe ... not like spacers and stuff which are against the law
you just measure the back of the hole from egde to edge
the ones i have are 54.1 corolla and 67mm(just under 7cm) if the hole is over 7cm then you need 73mm ones
i got mine when i purchased my wheels. normally you just get the nuts but the better places will provide full service and give you the hub rings as well.
Edited by kcorro
i got some mags with hubrings and nuts
only got 15" mags
i had 14" steel rim
the main reason i got some mags because the 14" suck in the wet and they only had 175/70/r14 tyres on them so they won't very wide.
i'll post some photo up soon
thanks everyone for your help
      Code P004B
      Upgrade from 2012 to 2023
    6. 3
      Towbars
    7. 5
      ASV50 Camry Head Unit Options
    9. 2
