rolla sportivo
You da man. Thanks.
Is it a no brainer to install - even for the motor mechanically impaired?
Looking at the dyno - would a 5-6 kw increase be what I could expect?
In the link to the fitment guide - you mention using a K&N pod instead of the TRD one. I assume the CAI comes with the TRD pod. Does that mean you discard that and have to buy a K&N one on top of that ? That'll add a could $$ to the price.
Gravity.
yes its a no brainer even I managed a fair few of them!!! :blink:
just take it easy and use the pics and all should be good ;)
if you do need a hand though just ask ;)
Yep thats about right for the increase B)
Thats right what you say about the pod's the TRD one does fit. but its VERY tight fit. and is a bugger to take off and put on again later (unless you remove the foglight)
The K&N extreme 3900 is the preferred pod (around $80-$160) but each to their own :D
