Is conventional automatic transmission the best choice?
Hi everyone, I own a 2017 Toyota Corolla Ascent Sport based in Perth, Western Australia. My car's navigation system currently runs on iGO Primo software (version 9.12.14.545514). I'm looking to update the maps and keep the entire system updated. I understand that the recommended method is to visit a Toyota dealer, but I'm interested in exploring if there's a DIY way to do this. Could anyone guide me through the process or provide any reliable resources or links? Here are the details of my current setup: Car Model: Toyota Corolla Ascent Sport 2017 Location: Perth, Western Australia Navigation Software: iGO Primo 9.12.14.545514 Specifically, I'd like to know: Where can I find the map update files that are compatible with my navigation system? What are the steps involved in transferring the map updates to an SD card and updating the system myself? Are there any risks or considerations I should be aware of before attempting a DIY update? I’ve looked through the user manual and some online resources but couldn’t find a comprehensive guide. Any help or pointers would be greatly appreciated! Thanks in advance! Best regards, -
Upgrade from 2012 to 2023
Towbars
5
ASV50 Camry Head Unit Options
