My AE82 SE
GAMEON
Hey peeps,
Thought i would share my new toy with everyone and see what you think.
When i first picked it up, it was in pretty bad condition, heres a picture.
I cleaned it up a bit, Welded and bogged an AE101 gtz bonnet scoop on to the bonnet for the topmount.
I cleaned up the engine bay a little, sprayed the rocker covers, picked up an ARC topmount for it, put on some blacktop 20v headers i had lying around and gave it a good service.
Picked up a FMIC for it, along with a Nevo 175mm crank pulley etc, installed the FMIC
Now with the FMIC i can get rid of the bonnet scoop, so got a new bonnet. It will be painted white soon. The intercooler is nicely hidden.
You can see the cooler if you look really hard.
Specs:
Car: AE82 Corolla SE.
Engine: AE101 MAP 4agze.
Gearbox: E58 LSD.
Exhaust: 2.5" Mandrel Bent, Redline headers, Lukey ultra flow muffler and race bullet.
Rolling Gear: 15" Rims with Toyo Proxes R888 semi slicks.
Brakes:-
Front: Twin-piston AE101 Levin conversion, with EBC greenstuff pads.
Rear: SX rear disc conversion, with EBC greenstuff pads.
Suspension:-
Front: KYB shocks, Kingsprings, Whiteline Swaybar & Whiteline Strut Bar.
Rear: KYB shocks, Kingsprings, Whiteline Adjustable swaybar & Whiteline Strut Bar.
Other Mods:
FMIC with custom piping.
Nevo 175mm crank pulley.
ABV done.
K&N pod
Fuel cut defender.
Specs:
117kws ATW's with cracked SC outlet pipe on 10-11psi.
14.3 at WSID when it was stock and detuned to 6-7psi.
Edited by Poggy
Update.
Got my car dynod at the toymods dyno day, got 117kws, found out later that day i had a 4-5inch crack in my supercharger outlet, hench the 3,000rpm idle lol, got it welded up, now running more boost and alot smoother power, pulls alot better.
Also some new goodies just came in:-
EBC Greenstuff front & rear.
Whiteline front HD swaybar.
Whiteline rear HD adjustable swaybar.
Front & rear whiteline strut braces.
All the bits for my 2.5" exhaust, Lukey ultra flow muffler, Lukey race bullet, X2 90 degree mandrel bends, X2 45degree mandrel bends.
Spotted you at Mt Keira on Saturday night, I think the whole country heard it when the cooler piping came off....
How much for the semis, if you don't mind me asking?
