Toyota Celica Campaign 4531H.
Sport1vo
Date: 28/09/2004
Supplier: Toyota Motor Corporation Australia Ltd
Category: Motor Vehicles
Product Info: Toyota Celica Campaign 4531H. Model code ZZT231. Production Period 22 July 1999 to 30 June 2000.
Defect details: In the brake master cylinder, there is a possibility that the recess that retains the rubber seal ring, located at the end of the cylinder body, may be corroded due to an improper washing process during component assembly. In this condition, brake fluid may leak from the seal, or a small amount of air may enter the master cylinder, which could lead to an increase of vehicle stopping distance.
Consumer action: Contact your authorised Toyota Dealer.
Make: Toyota
Model: Celica
Model Years From: 22 July 1999 to 30 June 2000
Consequences: In the brake master cylinder, there is a possibility that the recess that retains the rubber seal ring, located at the end of the cylinder body, may be corroded due to an improper washing process during component assembly. In this condition, brake fluid may leak from the seal, or a small amount of air may enter the master cylinder, which could lead to an increase of vehicle stopping distance.
Campaign Number: 4531H
http://www.recalls.gov.au/search.cfm?psa_i...recalls_vehicle
The following link will open in a new window and take you out of the Product Recalls Australia site.
The Department of Transport and Regional Services has overall policy responsibility for monitoring the conduct and outcomes of motor vehicle safety recalls in Australia.
  • 4 months later...
      Toyota Landcruiser problems
    3. 7
      selling car
      Fuel Filter - Change or not
      2013 cruiser gxl ute
    6. 2
    9. 1
      help with clutch
