help needed nolathane shaft bushes
sueplus4
newbie here . wondering if anyone can advive about the shaft bush as i need to replace them in my 99 model followed the forums and checked out the nolathane parts and that where i got stuck there are 2 different outside diameters and 3 different inside diameters sizes and so rang a dealer who was no help . hoping someone here might be able to help
thanks
sueplus4
thanks
sueplus4
which shaft bushes do u need& i'll give a part number ,Ive got the catalogue at home ..
thanks
sueplus4
Thanks for the reply , I have 3 different nolathane part numbers its the diameters needed for my model that i'm in need of . Toyota spare here in newcastle said they couldn't tell me as their system only gave a part number not diameters . That was even after giving my vin , Also tried toyota australia, who refered me backed to my local toyota spare part deptment . The local mechanic is willing to install at a decent price if i do the leg work of tracking down which bushes i need .
Nolathane part 49151 OD 33mm ID 12mm
49153 OD 33mm ID 14mm
49152 OD 35mm ID 14mm
any help much appreciated .
sueplu4
Edited by sueplus4
Ive got the same part numbers so were still in the same spot?!
My suggestion would be to get it off the ground & measure the shaft diameter with a vernier,I know it may be difficult but this may be only way to get the correct info/diameter,Itll prolly take ten minutes tops if the hoist is free or drive on ramps.thats if the local mech will allow it.
sorry took so long to answer but had a little luck . you can also by a complete coulping with the bushes already pressed in,after makert ,comes back to the same problem of diameters . Been to a different mechanic today their going to put up on hoist and measure the bolt size so that i get inside diameter.
THE COUPLINGS ARE AVILABLE FROM DRIVELINE SERVICES HERE IN NEWCASTLE THEY ALSO HAVE WEBSITE , DON'T KNOW HOW TO GET LINK IN SO THE ADDRESS IS
WWW.driveline.com.au
      RADIO CODES "HELP"
    4. 2
    7. 21
    8. 21
    9. 21
