Dyno
It will not affect the ABS brakes, just like how it will not affect the air bags :D
Well I got mine hard wired into the car. I don't think it will be too hard to reverse the wiring at all. If your after something that is plug and play (well kinda), then try sourcing a Fields Harness and use that to tap into the existing harness. Then you can swap them around. I couldn't be bothered with it at that time, lol.
Once you've got the PFC installed it sets the path for more exotic mods, such as valve springs, valves and stg3 cams :D
If the missus was not an issue then I would've of had a greddy s/c kit sitting on the table :(
