does any body own a camry sv-20 with 1s-ci engine?
scottyg
just want to know if anybody has had any troulbes with this particular engine because i think the swirl control valves are not operating and was wondering if these have any purpose for the engine/injection system?
Unsure but if you call Hamilton wreckers and ask for Chris he can tell you they have worked on SV20 EFI Camry 1800 cc 03 55719222
  • 11 months later...
Hi I have just spent an unproductive day on one of these cars it is running very poorly and has a great loss of power the owner has fitted new plugs fuel filter and timing belt.I have refitted the the timing belt with crank set at 0 degrees TDC and used the paint marks he put on for the camshaft pulley.It still runs poorly.Prior to the owner fiddling with the belt it ran well.Please can you help he has recently lost his job and cannot afford to take it to a local garage thanks;Dave.
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
