How to drive with "S" ?
Aftab
Hi room,
wass up ?
I have owned a 05`Kluger
I usually like to drive with "D". But there is a option to drive with "S" & I can controll it from my steering with up-down button.
it has four gear. should i change them my self or they will change automatically ?
can i drive always with "S" ?
My Kluger is : 2.4S four
pls help me. plsss..im very new here..
Thank you.
  • 4 years later...
If some one could provide answer for the quaestion could help many. I have the same problem. If not for old models, how is s used for new models, it could be the same principal. So please help him and me as well
the S is for Sport. It goes into S4, this means it will use gears 1-4
If you push lever in S mode forward, you will See S5, this means it will use all 5 gears.
If you pull, it goes to S4, S3, S2. This means the same, but wont go above the number chosen in the gear. Good for caravanning if you don't want it to constantly changing from 5th to 4th to 5th with slight throttle.
S mode should give you longer revs in gear.....maybe...hard to test really as depends how hard you push your right foot.
Some S-mode will auto-shift up when rpm hit redline. some will stay there and cut fuel.
Some S-mode will auto down shift when u floor it but some need to manually down shift. it depends on the settings.
