GPS Error
Sheryle
Sounds like there maybe 2 problems here.
The disc I gave you is a DVD+R Dual layer. So either:
Your DVD cannot read DVD+R Dual layer discs (which is most likely)
You need non-Toyota disc... coz your warning contains Japanese and I think you have a totally different system from ours.
Can anyone help
I need to know how to reset the GPS as it will not read the CD.
Does anyone know how to reset this :g:
I have attached an image of the error I am getting on the screen when I select Map button
looks like you have an import sat nav unit, had the same problem with a jap import surf a few month's back
was unable to source a compatible aust. map disc wound up fitting an a/market fujitsu system at $3000
same as gen. but a fair bit cheaper
Hi there - new to all this!!!
Do you know if my 2006 Kluger can read a DVD+R DL disc as i have one but nothing seems to happen when i load it... Should i try a DVD-R DL???
I am pretty sure a DVD+R DL works, since one person I have been PMing told me that he download a torrent copy from the internet, and was not able to make it work because he is using a DVD-R DL. Once he burns it to a DVD+R DL disc it works... could not remember what car he drove though.
Cheers Taka.
Is there anything special i have to do when i insert the disc or should it load automatically??
Cheers Taka.
Load automatically, and V14 will do some upgrade automatic when loaded the first time.
