03 kluger grande tyre
Tony Kluger 03 Grande
hi guys..
I owned 03 kluger grande.
my 2 front tyre is gone abit low... wannting to know has anyone fitted a wider tyre on their car.
i currently got 225-65-17.. just wanna know if it;s possible to fit 265-65-17 or 275-65-17???
has anyone fitted this size???
will there be any different on handing??
will it scrape the side of the car when driving offroad?
will it effect the fuel comsumption???
thanks
Hi Tony
Slightly of track of the questions you were asking, but if you intend to do a little off roading, a taller tyre will get more clearance between the diff and the ground. Onle marginally but every little bit counts. I guess the limitations come into it with clearance under the wheel arch though!
Does anyone know if you can get a suspension lift for the Klugers? What about Diff Locks?
Cheers
Edited by Nicho
One thing you have to also check before you go changing your tire sizes is how changing sizes will affect your overall rolling circumfrence. A good calculator that I like to use is:
1010 Tires - Tire Size Calculator
By inputting your specified tire size you get the following:
So that means if you move to 265/65R17, your speedo is going to be reading 7.184% slower than actual speed and moving to 275/65R17, you speedo will be reading 8.978% slower than actual. This will also throw your odometer out by that percentage. On the bright side though, your fuel consumption should be lower on the highway.
As well, with the stock 17 inch rim being 7.5 inches in width, you are on the minimum recommended wheel size should you opt for the wider tire. Usually it's best to be in between the figures for the recommended rim width, but that is usually just a personal preference type of thing.
hi...
y is tyre size 275/65/17 will gives me a lower speed reading compare to 225/65/17???
isn't it the same size rim and same ratio??
y wider tyre effect my speedo reading???
also will wider tyre means that my fuel comsumption gonna be more........
abit confuseeeeeeeeeeeee....
please explain......
