VOIP mobile calls on bluetooth
GEARO
Hi All,
I've just purchased a new Kluger (grande).
I have an older landcruiser with a nokia bluetooth unit that I've been using my Nokia E71 mobile phone for many years.
I have the phone set up to make and receive 3g VOIP phone calls.
Now when I pair my e71 to the Kluger, the incoming and outgoing calls are only seen by the bluetooth in the car when they are NORMALvoice call phone numbers. Whenever I try to make a voip call, ie: an internet call, the car's bluetooth does not see the call and I must use the phone manually.
When I go to make a normal call , againn all is ok.
I realise this is a specialised question but am unsure who or where I may go to answer this problem.
In summary when a call is made like 02498573xx@58.69.1.2 for example, the car's bluetooth ignores it.
HELP MUCH APPRECIATED As I'd be amazed that a new Toyota cannot handle this when every other "blue tooth kit" can !
thanks in advance.
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
