Fan resistor
Rony10
Hi all, my mum has a 1989 4 cyl camry, the first & second speeds on her heater fan are not workin , only the higher ones work, I had the same problem with my car and i just installed a new fan resistor and it fixed the problem, however i do not have a repair manual for her car so i would like to know were the fan resistor is situated on her camry.
thanks for any help
Usually you will find them attached to the ducting right above the blower motor (behind the glove box). If you have the new resistor pack with you there, just take off your glove box and look around the blower motor area for a panel that looks just like the back of the new resistor pack. Should be attached by two screws.
    6. 21
    7. 21
    8. 21
