Problem with door sills
Anyone who installed their door sills have issues with theirs?
The door warning light on the dash is slightly on even though all doors are shut. It would illuminate a little especially at night u can see it. It looks like it's faded but it's on. I know KT has done something to fix his by taping the wires completely but not sure if the issue he was having is the same. Can someone please let me know how to fix this?
from what I found, the wires are pushed onto the chassis quite tightly, and it can cut the insulation on the wire.
To find out where the fault is: open the door, keep the switch in and fiddle with the door sills, try this on all the doors and you should find the problem.
Wouldn't be surprised if one of your door sensor wire is slightly earthing.
Had no issues other then one of the rear sills came nice and bent with a crack in the rubber trim but i fixed by sticking it over the orignal sill and stomping on it a bit just hop it doesn't pop off now.
      Head Unit with Apple CarPlay
      Any RA 60 owners?
      Bluetooth stopped working
    6. 3
    7. 2
