[WA] Joint cruise 01/05/09 (tomorrow)
Upgrade from 2012 to 2023
Towbars
5
ASV50 Camry Head Unit Options
Hello all, Working on my 2002 corolla. It needs a engine rebuild due to burning oil out the back. It has over 400,000 km on it and I havent looked after it. Everything is still original on the motor. The only thing that I have replaced, was the brushes on the alternator. They were completely worn out. I am pulling the motor/gearbox out of the car. Wont know the condition of the block or head until I strip it down. I know the design of the piston where changed in the 2003+ models for more oil holes, which stopped the buring of oil. 1. Was there any other changes made ? 2. Does anyone know of where I can get a engine rebuild kit for 1zz-fe motor in australia ? 3. I have only found one place that I can get a new short motor built but that is in the USA and they do ship to australia but was hoping to find something in australia Thanks for help. Dragon
