NSW-For Sale... Pioneer CDJ 800 MK1..
GTL05T
Hey guys,
Gota PIONEER CDJ-800 Mk1 here for sale... I need it gone ASAP!! Heres the specs, the only thing that is missing, is the power cord... other than that, it works a treat!!! If ur interested, PM ME!! Asking price $550 SOLID!! PICK UP... If it doesnt go in a week, ill pull it of here.. msg me on 0423455502 my names wy... Cheers guys!!
Specifications
Performance Control CDJ-800
Quick Start Yes
Auto Beat Loop / Emergency Yes
Beat / Loop Cutter Yes
Quick Return Yes
Reverse Yes
Real Time Seamless Loop Yes
Loop Adjust Out Adjust
Reloop Yes
Memory CDJ-800
Cue / Loop Memory Yes
Shock-Proof Yes
CD Control CDJ-800
Jog Dial size 206,0 mm
Jog Dial type Touch sensitive
Jog Modes CDJ / Vinyl Mode
Pitch Bend Yes
Scratch Play / Cue Yes
Quick Scratch After searching Track
Fader Start / Back Cue start Yes
Relay Play Yes
Frame Search 1/75 Sec
Vinyl Speed Adjust Yes
Tempo CDJ-800
Master Tempo Yes
Tempo Control Ranges (CD) +/-10%, +/-100% WIDE
BPM Counter Yes
Front loading Slot-In CD Yes
Cue Functions CDJ-800
Auto Cue Yes
Manual Cue Yes
Real Time Cue Yes
Cue point sampler Yes
Display CDJ-800
Display yes
Jog Display Yes
Playing Address Yes
General CDJ-800
Media Loading Type Slot
Legato Link Conversion Yes
Anti Vibration Yes
Analogue Output 1 stereo RCA
Digital Output Yes
Type of Discs 12 & 8cm CDs
Disc Format CD, CD-R & CD-RW
Specifications CDJ-800
Frequency Response 4 Hz ~ 20 kHz
Signal to Noise Ratio 115 dB or more (EIAJ)
Distortion 0,006 % (EIAJ)
Power Consumption 21 Watt W
Power Requirements 220 - 240 V, 50/60 Hz
Dimensions (W x H xD) 305 x 109 x 344 mm mm
Net Weight 3,9 kg kg
    6. 21
    7. 21
    8. 21
    10. 3
