TWM Shortshifter for ZRE
shin0bi
to all the zre'ians & others,
http://www.twmperformance.com/shortshifters/toyotashortshifters/toyotacorollashortshifters.htm
anyone know if the '09 corolla shortshifter will will fit an australian zre?
by looking at the installation manual, it looks like it may..
http://www.twmperformance.com/manuals/2009-corolla-short-shifter-install.pdf
second thoughts please!!
cheers.
tom
The shifter is different to ours, the reverse gear, also they dont have the knob to lift up for reverse.
hmmm you've made some valid points vinh!
Tom, you could always email Frank from TWM. He might be able to confirm if someone else has ordered it and installed it on OZ ZREs with no problems.
thanks rowe, i'll give that a try
    2. 14
      Hi from Wagga
    5. 2
    6. 2
    7. 2
      Engine oil dipstick reading
    9. 1
      Landcruiser 13B Engine Swap
