obx helical lsd
daniboy
so i bought an obx lsd the other week but then i bought a whole gearbox two days later with a quaife in it instead for an awesome price, if anyone is keen on the obx unit gimme a msg!0403730371
Hey Daniboy
did you manage to find out if it works with our speedo gears with out any modification? or do our spedos run off the abs ? slightly confused lol..
Regards
dave
Edit: Has any one tried one of these guys yet , im very tempted but every single forum site is saying the build quality is poor and they need to be rebuilt, i wonder if the lsd would be strong enough with our engines in n/a condition.
Has any one done a obx lsd rebuild by any chance ?
Regards
My one looked good quality lots of Honda people run them no need to rebuild after 40,000 km!
Still working good
Did you DIY it with the washers, or did you get someone to do it for you? Can you make up another one if sent over to you?
Hey Daniboy
Regards
dave
Regards
Still working good
Best to get the factory one out theres a guide on newcelica for doing the lsd somewhere
Then check if it needs the speedo ring if your mechanic says yes it does
Then take obx and factory one to an engineer with a spark eroder cost me $100 bucks to get done
Then the factory ring fits on with a a thin slice of metal to keep it in place
Hey Daniboy
Regards
dave
Regards
Still working good
Is that pretty much it?
If there is more detail required within the steps, do you mind Pm'ing me all the information you know about it?
      ASV50 Camry Head Unit Options
    5. 14
      Hi from Wagga
    8. 2
    9. 2
    10. 2
