Programming guide keyless entry remotes
go see your dealer, there is nothing you can do. If you want more you will have to buy them from your dealer.
Thanks Northy,
Got two quotes from two different dealers in Melbourne,prices difference was amazing. Frankston Toyota $27.50 Chadstone Toyota $44.00 for programming remotes for a 2003 Corolla. Know where I will be going.
Kind Regards,
Lauschie
does that price include a new key as well?
is it the normal key or the remote access?
Bought two new toyota remotes on ebay for spares. Remotes costed $25.00 and programming costs $27.50 regardless of how many remotes you take in. Two remotes programmed usually cost $80.00 to $100.00 if dealer has to supply. Sales and Service at Frankston Toyota is awesome. Best dealership in Melbourne if not Victoria and maybe even Australia.
Regards,
Lauschie
Regards,
Lauschie
Programming done for free at Frankston Toyota,awesome dealership.
Regards,
Lauschie
  • 10 months later...
Gday guys and girls,
Has anyone got a programming guide for keyless entry remotes here. Can someone maybe tell me how to program new remotes that they work on my car??
Regards,
Lauschie
If it is the fob type ( not built in to key head ). These instructions should work.
With at least one functional transmitter
Lock and then unlock the doors using the transmitter.
Within 20 seconds of unlocking, insert key in ignition, turn the ignition key from the "OFF" position to the "ON" or “ACC” position 20 times, leaving the key in the "OFF" position after the twentieth turn.
Taking longer than 20 seconds from vehicle unlocking will not allow entry into programming mode
The vehicle's indicators will flash 20 times to indicate successful entry. Note the Toyota manual mentions starting this procedure with a door open then removing the key from the ignition. I suspect you may need to close the door for it to lock.
On the twentieth flash of the indicators, press the button once on each transmitter.( Maximum of three transmitters can be programmed)
Once finished, turn the ignition key to the "ON" position to exit from the programming mode.
This is for a Corolla zze122 but it may work for other models.
    6. 21
    7. 21
    8. 21
