What spark plug you using
i'm using the genuine toyota (denso) plugs. i think from memory they were around $90 for the 4.
if your engine is still stock, or even lightly modded, you won't get any performance gains from using a different or more expensive plug. you only need different plugs if it's force fed.
look in the FAQ section they should have it there
+1
But on a side note, I used NKG Platinum's in my 96 Camry and they did the job really well. I did both the leads and the sparks at the same time.
