2010 Corolla Cigarette fuse???
My cig lighter stopped working and now I cant use my GPS. <_<
Does anyone know the location of the cigarette fuse in the fuse box?
Is there another name for it because there is no reference to it as "Cig" like it should be??
ACC should be what you're looking for.
But as the part is a lighter and not a power supply, you may find the fuse is OK. If so, a new socket will probably be required. I hope it is just the fuse though ...
Edited by 450HP/tonne
Thanks,will check it out tomorrow.
I have used the ligter maybe 2 times to charge something, pretty silly if the socket stuffed up!! :angry:
Also, is it covered under warranty??
Edited by Kix
      Any RA 60 owners?
      Bluetooth stopped working
    5. 3
    6. 2
      Toyota Corolla Sportivo
