rubber hose
gloomis
gday all the other day i noticed small drips on the ground in driveway when i looked underneath the car which is a 2007 aurion sx6 i seen water dripping now and then from a bit of rubber hose can anyone tell me the reason and function of this hose thanks
That's the drain hole from your Air Conditioner evaporator. If the air inside your car contains moisture, it will condense on the evaporator and then needs somewhere to drain. That would be where it does.
