2003 camry sportivo Power for my Amp
Sammykinzz
Hey All.
Just wanted to know what all you guys reckon and where you guys put the power cable for an aftermarket AMP, Where is the best place to put it through the firewall?
Might have been answered before?
In the engine bay on the left hand side (under the VIN plate area) there is a rubber cone/dome that has a tube coming out of it. You can cut a hole/slit in it and run the cable through it. The cable will feed behind the glovebox.
      Centre Bearing Replacement
    3. 6
      maps in 2017 Camry Altise
    6. 5
    7. 4
      Front Cameras
    9. 51
    10. 51
