Speedometer Upgrade need help!
I am looking to replace my existing boring speedometer with white face to a JDM speedometer with black face.
This black face speedometer also used in Levin model and it is completely dark when the ignition is off.
As soon as the ignition is on, the speedometer will light up itself and dim itself when sidelight is on.
My existing speedometer doesn't has this feature, does anyone know whether the Ascent model will be compatible with JDM speedometer?
post-22906-0-23128600-1338385579_thumb.j
post-22906-0-45675200-1338385582_thumb.j
plug and play
Thanks for your response.
Will I get the JDM speedometer feature on my Ascent?
Light up itself when the ignition is on and dim itself when the sidelight is on.
Just want to ensure this feature is available after replaced the speedometer, if not you can't really see speedometer during daylight.
Edited by the-converter
u can only go to the wreckers and try. are u in victoria? u can try my stock stivo cluster to see if that works. levin works in mine but again mine is the one that is on all the time.
