ZRE WHEEL HELP .
Kreezy*
Hey guys I found a set of wheels and i was wondering will this fit my zre the specs are :
Front wheels :18x8 (235/40/18")
Rear wheels :18x9 (265/35/18")
Stud pattern :5x114.3
Thanks guys .
Not sure about the rear width but good chance front is alright..
According to the ZRE FAQ which can be found here
The stock wheel sizes for the ZRE are:
i) Ascent: 15x6 steel with 195/65R15 91H tires
ii) Ascent Sport, Conquest, Levin SX/ZR & Ultima: 16x6.5 +45 alloy with 205/55R16 91V tires
Stud pattern: All grades - 5x114.3
Wheel nut thread: M12 x P1.5
Want to buy wheels? Check first using Wheel Offset Calculator & Tire Size Calculator.
Generally, people have gone 17"/18" by 7-8" wide rims with +35 to +40 offset. Best to search or ask/PM someone first before buying!
Thanks guys .
Those tyres are way too wide. Offset helps too.
If you can, get the wheels without the tyres. PM filipsta24, i think he runs the same rim widths.
way to wide, i was running 18x8 +35 with 215/40 and 18x9 +35 with 215/40.
if you want to run tyres a bit bigger 225/40 will also fit on the 18x8 and 18x9, but 235 and 265 are just a bit to big
the new specs of my new wheels are 18x8.5 +35 and 18x9.5 +30, not sure on tyre size yet so i just have to wait till they get here....*sigh*
Hey again I found another set of wheels online and I was wondering if these specs would fit a zre :
Specs:
17x8+45. 215/40/17"
17x9+45. 215/40/17"
    2. 14
      Hi from Wagga
    5. 2
    6. 2
    7. 2
      Engine oil dipstick reading
    9. 1
      Landcruiser 13B Engine Swap
