Hi all I'm having a problem with my 1994 22r Toyota hilux, it cranks but will not start. It started perfect twice the day it happened and the third time nothing.
Can't smell fuel from the carby and and did a spark test and not getting any spark as well. I've tested engine fuse, ignition fuse, AM1 and AM2 fuse and they test OK. Replaced Spark Plugs, ignition leads, distributor cab and coil pack. Battery tested OK and both positive and negative battery clamps are clean. Checked resistance on ignition switch and which was fine. Ran electrical cable from 12v wire from igniter harness at plug to multimeter and from multimeter to 12v wire ignition switch wire harness plug and and got nothing.
Is their another relay under the dash I don't know about which isn't supplying the 12v? Has anyone had this same problem?
    2. 1
    3. 0
      Tyre Sale Specials
    4. 10
      Android auto
    6. 0
      Remote start
    7. 1
    8. 1
    9. 10
      Android auto
    10. 10
      Android auto
