prado 3.4 v6 5vz-fe high idle
jas72
Hi Guys
this is my first post on a forum.
Have an issue with high idle on a 1999 prado that myself, mechanic and auto electician and also electronics technicians can not solve
The air flow meter, isc valve, and tps are all within spec.
Have all the correct voltages at ecu.
replaced sensor for coolant and has been tested as working correctly,
ISC and throttle body cleaned, isc tested open and shut on 12v.
The engine has been run on computer with nothing showing up, timing perfect.
Im suspecting the ecu as the cause.
The funny part is that if the coolant sensor is pulled while running, the engine runs perfect and idiling at 750 compared to its normal 1100.
Any ideas would be appreciated.
regards
jas
Edited by jas72
  • 4 months later...
      New member seeking advice for parts
    2. 39
      Pics of my Kluger steering wheel removal
    3. 14
      1zz to 2zz
    4. 0
      Can I put a 2010 bumper on my 2008 Camry ?
      Anyone else tried these seat covers ?
    6. 1
      Digital Speedometer
    7. 0
      am2 fuse blowing
      Toyota Celica '96 5S-FE no spark
      Toyota Camry 2003 Driver seat recline issue
