Re: TRD Aurion vvti pipe
2GRMR2
Hi all
I am new to the forums and have just purchased a complete Trd Aurion engine bundle to do an engine swap
I am having trouble getting a part number for the all metal vvti pipe
So far toyota have supplied a trd fix kit which was just a rubber hose and clamps
Then they ordered a new pipe but this still has the rubber hose in the middle
Has anyone replaced their hose with all metal and is there a part number available
No solid metal part. Only the rubber version as the TRD oil pipe routes differently and don't think they could be bothered producing a limited run of metal pipes.
Part you need is A132E0102F. £81.00 listed .
Picture shows old pipe but I checked Exige V6 and
it's picture shows new part but both list new part
number which is all metal pipe.
post-35126-0-91929100-1408765603_thumb.g
Cool that's what I need, pity Trd never released the revised pipe, seeing as the Evora uses the same supercharger setup , Toyota probably supply the upgraded pipe to lotus anyway
Edited by 2GRMR2
Probably because TRD Australia (the makers of the TRD Aurion) ceased to exist almost 2 years before the supercharged Evora S was released. In fact, TRD Australia stopped making cars before the the VVTi oil pipe issue really started gaining attention in Australia...
Hi ya.
I'm wrecking an '07 TRD (SL) in WA (should be finished by 27.08.14), so there are original TRD parts available ...
If anyone wants to send me an email bid for parts, read points 1 to 4 at the bottom of post #1 (current bid for brakes are at post #10) ...
http://au.toyotaownersclub.com/forums/topic/48118-trd-wrecking-in-wa/
Craig
The TRD Aurion VVT-i oil pipe routes differently to the N/A 2GR-FE VVT-i oil pipe. The revised metal pipe for the N/A Aurion will NOT clear the supercharger drive belt.
The solution for the TRD Aurion is the same as the original solution for the N/A 2GR-FE which was to replace the hose and clamps only. The all-metal pipe was not as a fix for the existing engines, but as a new part to be used on future produced engines. As such, this new all-metal pipe was designed for the N/A 2GR-FE.
I would not be surprised at all if the Evora S simply uses the same metal/rubber combination.
Edited by Tard
Exige and Evora all use new metal pipe
Possibly very first Evora ' s used 2pc
pipe but all use full Metal pipe now
post-35126-0-09204700-1408876752_thumb.j
Edited by 95wrc
No problem . This is a design flaw and if I owned a
TRD Aurion I would order Lotus part. Big reason for
many fires in early NA versions of 2gr.
      Code P004B
      Upgrade from 2012 to 2023
    6. 3
      Towbars
    7. 5
      ASV50 Camry Head Unit Options
    9. 2
